2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-29T23:30:27+00:00
    FYI: The Surface pro 2 January Firmware and Driver Pack is available for download.
    http://www.microsoft.com/en-au/download/details.aspx?id=40856
    This includes:
    1. January2014SurfacePro2.zip
    2. Surface Ethernet Adpater.zip [sic]
    If we got the January firmware update, do we have some or all of this?  If we've installed the patch Tuesday updates too, do we have all of this?  I can't tell from looking at my update history.
    2014-01-30T01:32:54+00:00
    I ran the powershell script and some drivers installed from that zip file. Some failed. I still see an unknown device which is the telemetry driver which I can't get to work no matter what method I try, even the script method described in another thread.
