2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-29T05:23:58+00:00
    FYI: The Surface pro 2 January Firmware and Driver Pack is available for download.
    http://www.microsoft.com/en-au/download/details.aspx?id=40856
    2014-01-29T12:16:00+00:00
    Something I can confirm about the January Driver Pack: Intel HD drivers in that pack finally solve the banding and black pixel artifacts seen in certain images (scpecially artificially created images, which are more prone to have long, continuous color gradients) . This problem was introduced by the December firmware/driver fiasco and until now the only solution available was installing Intel's latest official HD drivers. Unfortunately, every single driver/firmware update since December reinstalled the faulty HD drivers, so you had to constantly reinstall Intel's official drivers. After installing January driver pack I no longer percieve artifacts caused by lack of screen color depth. I miss Intel's HD control panel for the graphics adapter, though, but I can live without it as long as my Surface performs the way it should.
