2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-29T00:02:27+00:00
    I haven't had any battery issues with my SP2 besides the one mandatory "first time comes around" that healed itself With a reboot.
    Anyone else who could confirm that a reinstall of the battery driver/FW resolves the issue and/or resets the battery- meter?
    During my drain to 0% battery calibration, I noticed the unit was still running for another hour after the battery meter reported totally depleted. So yes the readout was wrong.
    The energy settings do not allow to set critical energy level to 0% nor doing nothing if it hits the 5% limit (there is no option to do nothing).
    How can I force it to run until it is 100% depleted?
    Adjust your critical battery action to sleep instead of hibernate. Once the readout gets to 5% manually wake the unit and it should stay awake. "Should" as in it worked for me, mightn't work for everybody.
    2014-01-29T01:22:55+00:00
    The only way to get some response to something like this would be a class action suit.
    I'd have expected the following:
    • Some battery capacity loss over a 3 months
    • Some jitter in the battery capacity readouts
    Is a 4% loss over 3 months (and 26 cycles) really statistically different from the expected?
    I don't know much about batteries, but I do know that any battery I've had in a computer has lost substantial capacity over a year or two.  Is Microsoft really doing worse than industry norms?
    I can imagine that batteries that got fried due to the waking-up problem will have loss of capacity, but is there really evidence that others were harmed?
