2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-28T23:14:39+00:00
    I haven't had any battery issues with my SP2 besides the one mandatory "first time comes around" that healed itself With a reboot.
    Anyone else who could confirm that a reinstall of the battery driver/FW resolves the issue and/or resets the battery- meter?
    During my drain to 0% battery calibration, I noticed the unit was still running for another hour after the battery meter reported totally depleted. So yes the readout was wrong.
    2014-01-28T23:22:58+00:00
    The energy settings do not allow to set critical energy level to 0% nor doing nothing if it hits the 5% limit (there is no option to do nothing).
    How can I force it to run until it is 100% depleted?
