2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T23:45:22+00:00
    I have noticed this as well. Try running "powercfg /batteryreport" which will generate battery-report.html file. When open that page, I see my battery full charge drops to around 22000 (don't remember the exact number. I'm doing System Restore on my Surface Pro 2 at the moment.) It should have been around 44000,
    which is the normal full charge capacity.
    I think that is why battery percentage is always 100%, until you have used it more than half then it will start dropping because its actual capacity will be less than 22000.
    WTH! This is so disappointing..
    2013-12-13T00:54:13+00:00
    The Full Charge Capacity in batteryreport.html is the best guesstimate from the electronics associated with the battery on how the current actual charge capacity compares to the design capacity (theoretical ideal for that battery model).  I only take seriously the Full Charge Capacity that "powercfg /batteryreport" generates after I discharge to less than 10% and fully recharge to 100%, which I only do once every 3 months because of my relatively low usage and wanting to avoid undue wear-and-tear on the battery by fully discharging and fully recharging (see Wikipedia or Battery University on the characteristics of Li-ion batteries).
    If the 22,000 mWH were real, the battery would be really screwed as the design capacity is 42,002 mWH.  My Surface Pro 2 has been through about 12 or more equivalent full discharge-recharge cycles (partial cycles are added up) and my Full Charge Capacity is reported as 41,859 mWH but it goes up and down daily depending on my pattern of usage, how cold the machine is, etc.  As I've reported in other posts in this thread, to maximize the life of my $1400 device with irreplaceable battery, I mostly try to keep the charge state of my battery between 35% and 60% and I try not to let it get too hot in charging or in use.  Heat is bad for Li-ion batteries.  Apple in their battery care web pages recommends for prolonged storage of the devices having the charge at 50%.  They claim their devices will have 80% charge capacity have 1,000 cycles (don't say temperature or whether that's full discharge-recharge cycles, etc.).  So given that, if the discharge rate is multiplicative (same factor retention capacity on each recharge, you can figure out that you lose 0.999777 of charge capacity on each full discharge-recharge.  0.999777 raised to the 1,000th power is 0.8, 80% full design capacity after 1,000 discharges/recharges, according to Apple (their math may be different).
