2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-28T21:06:09+00:00
    after all firmware updates applied:
    after reset (power up + volume up hold x seconds until surface logo flash twice)
    4% loss. Before the December update, this machine was reporting no loss. I'm convinced the firmware update in December permanently damaged people's batteries. I'm not sure how users can organize around here to have MSFT own up to this and replace people's surfaces. I think the only way will be for NEW surface owners to watch their batteries and if after 10-20 cycles they haven't lost 4%, it would indicate MSFT basically damaged our new hardware....
    That or there is a bug in the tools they have provided and the perceived losses aren't correct. I'd hate to think my device was damaged by a firmware upgrade. But I do vividly recall wild variations on battery behavior just after the update. I suspect the December firmware may have caused over-charging based on reports of overheated devices, and I myself experienced one such incident, or a month of under-charging finally took its toll. I almost feel tempted to buy another surface just to confirm, was it not for the fact I may never buy a surface again after this experience...
    I had a tech help me yesterday to reset my battery. My battery life seems to be better.
    No guarantees but worth a try:
    Make sure to Plug your surface in-must be running on ac power
    Open device manager and locate batteries
    Click on Microsoft ACPI-compliant control method battery
    Right click and select uninstall
    restart the surface
    This is supposed to mimic installation of a new battery to the surface firmware
    Did any of your battery statistics (like wear, etc.) change in a positive manner?
    Yes.  my battery went from showing a wear level of 3% to 1% and I have been using my surface for about 4 hours today on battery only and still have 68% showing on the battery level indicator
    2014-01-28T22:28:30+00:00
    I haven't had any battery issues with my SP2 besides the one mandatory "first time comes around" that healed itself With a reboot.
    Anyone else who could confirm that a reinstall of the battery driver/FW resolves the issue and/or resets the battery- meter?
