2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-27T18:30:39+00:00
    My Surface pro 2 won't sleep or hibernate like it used to before the January update leading to a significant difference in battery life, I can only just manage 4 hours with the default power saver option on!
    Using "CPID Hardware Monitor" my battery wear is 3% after 31 cycles.... that's fairly bad considering I've only had it since Christmas!
    Anyway my main concern is the battery life at the moment as I'm up to my head with college work and i need it to last me 7-8 hours like it used to.
    Is it worth ringing support up and seeing what they say?
    2014-01-27T19:59:42+00:00
    SP2 128Gb
    6% battery capacity loss after 36 cycles and 1 month of use. Seems excessive to me.
    Performed battery calibration as well as Power+VolUp 15sec resets, no change.
    Should I send the unit for a warranty claim?
    Thought about that already, too.
    May I ask how you did the calibration?
    I never even nearly used it outside the operating temperature range.
    Just compared with my Thinkpad. In over 9 month and 153 cycles its battery merely lost 2% capacity (from 47520mWh to 46730mWh).
    Another issue I noticed just now: the 1-18 update got installed three times, on 1-20, 22 and 26.
    In the battery report under "Usage history" there is no data listed since 01-23, neither battery nor ac duration.
    Knuckle-dragging rockape calibration system learned from YouTube I'm afraid... I let the battery drain to zero and then recharge till full. It is a maneuver that shouldn't be repeated too often.
