2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-27T14:28:53+00:00
    SP2 128Gb
    6% battery capacity loss after 36 cycles and 1 month of use. Seems excessive to me.
    Performed battery calibration as well as Power+VolUp 15sec resets, no change.
    Should I send the unit for a warranty claim?
    Thought about that already, too.
    May I ask how you did the calibration?
    I never even nearly used it outside the operating temperature range.
    Just compared with my Thinkpad. In over 9 month and 153 cycles its battery merely lost 2% capacity (from 47520mWh to 46730mWh).
    Another issue I noticed just now: the 1-18 update got installed three times, on 1-20, 22 and 26.
    In the battery report under "Usage history" there is no data listed since 01-23, neither battery nor ac duration.
    Yah, I'd like to know about the calibration, too. 5% degradation after 29 cycles.
    2014-01-27T16:04:40+00:00
    UK SP2 128
    Meanwhile back on the firmware/hardware updates treadmill...
    I have just been offered and installed a "hardware" update dated 18/01. My update history already had an entry listed for this date (annotated "firmware"). Subsequent to the latest installation I now have two installed updates recorded as issued on 18/1, both described as "firmware". Now I don't really imagine a hardware update is different to a firmware update unless they can now send PCBs and components via broadband. But this sort of inconsistency in simple nomenclature is breathtaking from a corporation of the size and scale of MS.
    I've tried to get an answer to the following question several time, but maybe someone could please clarify the situation for this weary old geezer.
    In the past, before installing any update, one could always go to the MS KB and read a description of the patch's functionality and relevance before installing (or not). This now seems impossible. Clicking on "details"  of the checked update simply takes me to the top level of the MS support site. Which is, in this context, absolutely useless.
    Is there any route by which one can investigate the (no longer numbered and thus vague and ambiguous: see above) updates before installation? If not why has this essential information become hidden?
    Thoughts on battery performance:
    Occam's Razor would seem to apply here. The simple way to solve the battery problems being discussed is to design the products with interchangeable/replaceable batteries: as always in the past! This regression to a situation where a serviceable device must be abandoned or confined to mains-tethered use when the battery performance has declined significantly is an outrageous development, pioneered, inevitably, by Apple - if you discount electric toothbrushes. Some of us have to make these purchases last a while. My  Vaio (&XP) which the Surface Pro2 replaces is still usable (just) after >7 years, although it has consumed 3 batteries in that time.
    Roy
