2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-27T10:42:24+00:00
    That's interesting: Just checked with "CPUID Hardware Monitor"
    Designed Capacity=42002mWh
    Full Charge Capacity=40678mWh
    Wear Level=4%
    Even if that is true, a loss of 4% capacity after 19 cycles (in 6 weeks) is way too much, I think?
    SP2 128Gb
    6% battery capacity loss after 36 cycles and 1 month of use. Seems excessive to me.
    Performed battery calibration as well as Power+VolUp 15sec resets, no change.
    Should I send the unit for a warranty claim?
    2014-01-27T11:58:30+00:00
    SP2 128Gb
    Thought about that already, too.
    May I ask how you did the calibration?
    I never even nearly used it outside the operating temperature range.
    Just compared with my Thinkpad. In over 9 month and 153 cycles its battery merely lost 2% capacity (from 47520mWh to 46730mWh).
    Another issue I noticed just now: the 1-18 update got installed three times, on 1-20, 22 and 26.
    In the battery report under "Usage history" there is no data listed since 01-23, neither battery nor ac duration.
