2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-27T00:09:36+00:00
    With the 1/18 update, I think an issue is when I have the power button set to sleep.  If I press it and then close the lid, it does not seem to sleep correctly.  I tried setting do nothing with the lid, but still issues.
    I have now set the power button to hibernate and the lid to sleep and it seems ok.  Of course, I can just not press the power button and close the lid to just sleep.  Maybe just coincidence.
    2014-01-27T02:24:05+00:00
    Hello man, I have the same issue, I change my button function to hibernate because the surface crash when enter to sleep mode. Very sad with my experience in the surface pro 2
