2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-26T22:52:55+00:00
    I've now encounted this problem of battery drainage since i installed the latest update on the 18th January. I got the Surface Pro2 at Christmas.
    Before the update, i would press the power button that would make it go to sleep, after 10 mins or so it would hibernate and save my battery from decreasing rapidly like it is now. When i press the power button, the surface logo would show meaning it had awakened from hibernation.
    Now however, i press the power button and it does go into sleep mode, after 10mins/30mins i will press the power button to find it is still in sleep showing my lock screen instead of the suface logo then booting its self.
    I've just installed "CPUID Hardware Monitor" and i will continue to monitor this issue by this program but at the moment with all my college work, i can not be doing with this issue and I'm very tempted to get a refund!
    (My battery wear after 31 cycles is 2%)
    2014-01-26T23:29:50+00:00
    P.S. I don't run CPUID all the time because it is undoubtedly a bit of a battery drain itself.  I only run it periodically mostly to check how my SP2 is doing temperature-wise. I figure the inlet, pant, and SSD assembly temperature are somewhat indicative of how the battery is faring temperature-wise.  I've been using it since someone else in this forum first mentioned CPUID many post ago.
