2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T22:56:23+00:00
    Greetings BCVHOG,
    What error message do you get? Can you upload a screenshot for us?
    Steven_B, any word from Microsoft on this?  This is becoming a very widespread issue so would be good to know if MS is going to release an out of band fix for this.  Multiple impacting issues with this update and I don't think people need to wait for a month to get a fix.  It's made many people's experience with their Surface worse than before the update.
    2013-12-12T23:27:22+00:00
    I am another SP2 (512Gb) user that has this problem with a failed firmware update.  I tried the "net stop wuauserv" procedure listed above but it does not work for me.  Hopefully Microsoft fix this soon ...
    One thing I have noticed since the attempted update and failure is infinite battery life for some reason.  Now I don't think I have discovered limitless energy, rather the system now has no idea how much power is left.  Not sure how to fix that yet.
    I have just noticed the same issue with the battery life display...stays on 100%
