2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-25T12:56:01+00:00
    Full charge capacity should be ok again.
    This problem seems to occur seldomer after the 1/18/2014 update, but it is not quite gone...
    Thanks... but I did this already several times. No change in the battery report.
    Another issue that just recently came up is when the SP2 is charged to 100%, then unplugged the battery indicator stays at 100% for hours. Sometimes a simple restart fixes this.
    However, I am virtually forced to perform "this nice old trick" at least once a day.
    It is frustrating...
    2014-01-25T13:23:25+00:00
    What you describe sounds to be an expected event given you are observing 22mWh Full Charge Capacity.  I would expect approximately half of your battery life to say 100%.  As you reset your system, check for the relationship between your batteryreport and your observation.  If batteryreport still shows a low number, try holding the reset keys for significantly longer period.  As for long term solution, so far none has presented itself.  You may consider using hibernate instead of sleep until one is found (assuming this occurs as a result of sleep).
