2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-25T10:42:49+00:00
    Since the january firmware update my SP2 128 GB goes into sleep and hibernate properly.
    My main concern is the battery report:
    Full charge/design capacity
    http://www.picfront.org/d/94lC
    Battery life estimates
    http://www.picfront.org/d/94lB
    Full charge capacity dropped from 42mWh to 22mWh in one month.
    My guess is that's hopefully just a software failure. Anyone else noticed such a dramatic decrease?
    2014-01-25T12:15:28+00:00
    You need this nice okd trick:
    1. Switch off your Surface.
    2. Hold down the volume+ key at the left side of your Surface and simultaneously hold down the on/off key at the right top of your Surface for at least 15 sec,
    3. Release both keys
    4. Wait another 5 sec
    5. Switch on your Surface and control the battery report.
    Full charge capacity should be ok again.
    This problem seems to occur seldomer after the 1/18/2014 update, but it is not quite gone...
    wt
