2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-24T10:59:28+00:00
    I have a UK 256GB SP2.
    I actually didn't realise that sleep was only meant to wake with a touch on the Windows symbol by the screen. Just put the device to sleep from the menu and sure enough, you are right!
    That means mine doesn't put itself to sleep properly either. It just turns off the screen.
    2014-01-24T12:59:10+00:00
    I have a SP2 256GB. I had the problem of the December FW which was causing it to wake up.  I received the 18th January update and installed it and now it doesn't wake up by itself.  However it now does not go to sleep or hibernate on its own
    Battery settings in advance power control
    Set Display timeout of 2 mins
    Set Sleep after 5 mins
    Set Hibernate after 10 mins
    Running on battery after 2 mins the display times out but even if you leave it for an hour it hasn't entered sleep mode or hibernate. If you touch the screen (in the centre) it wakes up instantly.  If it is in sleep mode the only place you can touch it to awake it, is the Windows symbol at the bottom centre of the screen.  If its in hibernate then you see the surface screen when it start up
    I contacted support and they seemed to confirm this as known and offered a replacement.  I've been following this thread but have not noticed reports of this.  Any comments ideas?
    Additionally but not repeatable the display timeout does not activate.  I left the SP2 on the desk and when I came back 1 hr latter the display was still on and it has done this several times but I can't predict when it occurs
    Jon
    I too am in the same state.  Sleep is a problem (not personally :) ).  I had done an advanced replacement, and the device they sent me had the exact same issue.  It was a 4200.  Total time suck and waste of my time.  I've resorted to only Hibernate at this point.
    I'll be getting a Dell Venue now, as this device is a total PITA.
