2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T22:22:19+00:00
    It just dawned on me this morning, I noticed some degradations back in the past Win8.1 update. Things like app crashes leading me to run several System File Checker (sfc) but in the back of my mind, i was thinking that this update would fix them. I think this is why it's taking Microsoft so long to figure out the problems.
    2013-12-12T22:55:15+00:00
    I am another SP2 (512Gb) user that has this problem with a failed firmware update.  I tried the "net stop wuauserv" procedure listed above but it does not work for me.  Hopefully Microsoft fix this soon ...
    One thing I have noticed since the attempted update and failure is infinite battery life for some reason.  Now I don't think I have discovered limitless energy, rather the system now has no idea how much power is left.  Not sure how to fix that yet.
