2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-23T19:29:55+00:00
    Would someone from Microsoft please let me know what I can do when the battery performance drops below the level which makes my SP2 a useful portable tool? Will a replacement battery (or unit) be available? If so what is the anticipated cost of this service? If not, then what?
    Roy
    2014-01-23T20:04:02+00:00
    Roy
    A replacement unit should be available if you're covered under the manufacturer warranty. Contact support through phone or email.
