2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-23T18:11:38+00:00
     I certainly can't previously recall a situation comparable to where the "updater repair tool" is itself broken. Astonishing. And their lack of clarification of the Surface update situation is simply a disgrace.
    I've seen worse.  Oracle not only had Java bugs, but a few months ago their bug reporting tool was broken and the email address for reporting problems with the bug reporting tool bounced.
    But the opacity of Microsoft's bug reporting system is well illustrated by the discussion at http://answers.microsoft.com/en-us/office/forum/office_2007-excel/how-do-you-report-a-product-bug-to-microsoft/0ef12a13-78eb-40c1-b946-f963cbe26b6e
    One of our conclusions about the value of experts on forums in medicine was that a major impediment was the "free rider problem" of people associated with other healthcare providers benefiting as much as people associated with the expert's own institution.  But the free rider problem doesn't apply to the situation with Microsoft products.  And we're talking about bug reports, not technical support., so this doesn't require the same sort of investment that Apple made placing "geniuses" in stores.
    The ability to inform Microsoft about bugs seemed to work pretty well until ~2005, and since then Microsoft has become pretty bureaucratic and impenetrable.  Some others has gone downhill also - for example, one used to be able to add addendums to Java bug reports but that is now gone.  But in the same period Apple improved.
    This is something a new CEO can turn around.  As an example, the Surface is a much better model of tablets than the overgrown phones that other companies are selling.  Microsoft needs to reconnect with its techie roots and leverage its advantages.
    2014-01-23T18:28:05+00:00
    The January Firmware update fixes the sleep / hibernate issues but the incorrect battery indicator is still present.
    There is also a problem when using a micro sd card with the device. The CPU usage stays at around 20-30% after cold booting / waking the device with a micro sd card installed. This causes the SP2 to constantly use power and decreasing battery life.
    The only way to bypass this problem is restarting the device but if it sleeps and you wake it up you're back with the same problem. The best solution is avoid using an sd card if possible until a fix / update is released.
    I always wondered why my SP2 lasted 7-8 hours on 50% brightness and after installing an sd card I average about 5-6 hours.
