2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-23T07:00:37+00:00
    I still have sleep issues, while lying unused with screen off and the type cover attached covering the screen over night the battery level went from 50% to 6%.
    I also get the sense that the drain when connected to the Type Cover is not fixed, but I haven't done any detailed testing.  From Microsoft's listing at http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history it sounds like there were multiple issues addressed in the failed 10 December firmware update, most of which were not addressed in the 18 January  firmware update.  It is unclear if Microsoft thinks more than a handful of people have these problems; they seem to think they addressed the most common problem, which they think was experienced by 0.3% of users, and it is hard to tell if they think there are other problems that need solving.
    BTW, URLs such as that above have been going into infinite loops when used in IE in the past week or so.  They are OK in other browsers.
    I found with sites IE11 hates with win7 64 - I do tools->compatibility settings->"then add the url to the list" and then it works
    had this problem with battle.net and others - although your one seems to work ok for me
    2014-01-23T15:12:16+00:00
    It is odd that Microsoft URLs would not work with the current version of Internet Explorer on the most common Microsoft operating system, Windows 7.  It is good to know that there is a way of patching this problem. but if Microsoft can't make its own URLs work with its own key software, it is not very focused on a basic part of interaction with customers.
    In the golden age of Microsoft there used to be multiple ways of giving Microsoft a heads-up about a problem, and one frequently got an immediate appreciative response.  There is the charming story of the (now) Melissa Gate describing her first date with Bill Gates being at a later hour than she expected in the evening because Bill was going to a user group meeting.  She found that a bit geeky, but that was a big part of the spirit that made Microsoft great.  Today much of such activity is relegated to these forums, and there is almost no feedback as to whether Microsoft is paying any attention.
    If I were advising the next CEO of Microsoft how to regain the magic of the golden age, a key part of that advice would be to have some real Microsoft employees with actual authority involved in these forums.  I've seen and written about such a model working in medicine, and the added value is tremendous.
