2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-22T20:28:46+00:00
    Useless unit! This will be the second time I will return it. Last time it was the USB port and pen calibration not working. Now the battery drain is to fast without any reason. 17% battery drain/hours with absolute minimum use while others claims over 8 hours, wtf!
    EDIT: at 8% battery life the unit suddenly goes into sleep mode even after I set it to go into sleep mode at 5%. When I press the power button I can login to windows and the batterybar shows 0% and unknown battery status. The unit can still be used even if it shows 0% for couple of minutes before it definatelly powers down. When I charge the unit it doesn't increase the battery level even after 1 hour. Shutting it down and restarting shows correct battery charge. October firmware and January firmware installed (never received the december firmware).
    2014-01-22T21:30:49+00:00
     From Microsoft's listing at http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history it sounds like ....
    BTW, URLs such as that above have been going into infinite loops when used in IE in the past week or so.  They are OK in other browsers.  It makes you wonder what browser people at Microsoft use.  It also makes you wonder whether they even know of the problem with such links since they seem to avoid forums such as this one where they could get rapid reports.  I would have mentioned the problem as soon as I saw it if I thought someone was paying attention, as Microsoft folks used to do before the week in which employees #1 and #3 in seniority left within a few days of each other.
    The problem with some Microsoft URLs that I described recently occurs with IE11 on Windows 7, but after  Jim Lewis said he couldn't reproduce the problem on windows 8, I checked and indeed it is not a problem on either the Metro or Desktop sides of Windows 8.
    That explains why the Microsoft folks haven't fixed this.  They have probably all moved on to Windows 8, and even if a problem is noticed in Windows 7, it is not high priority to them to fix, even though far more people use Windows 7 than Windows 8
