2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-22T17:57:02+00:00
    Well, then you have an exceptional copy of SP2. It makes you wonder if its worth to keep it or return it back for exchange. I have no other issue with the unit as everybody else describes here, except for a (compared to yours) very low battery life. 9 hours seems to be a bit exaggerated. How do you measure. I measure with an actual run of 5,5 h with office softwares before it shuts down, while you are maybe switching it on and off during the 9 hours period.
    Take a look at the other responses in this thread- your 5.5h of run life is way off.  Exceptionally low.
    See here on the CNET review.   They get 7 hours of run time playing video, which is pretty darn intensive.  So your 5.5 is abnormal. I'd look at a replacement.
    2014-01-22T19:49:33+00:00
    @SV-82 5.5 hr battery life concern
    The battery life estimate in the battery report does include periods of inactivity.  Looking at days in the past week, my average battery life estimate for a whole day has ranged from 6 hr to 9 hr.  And I have a very low screen brightness, 10 to 15%, as I'm an old retiree living in a house surrounded by shade trees (live oaks).  So if all your usage is processor-intensive and you use a very high screen brightness, I could see getting only 5.5 hours battery life.  The one full day of usage (1/21) after the 1/18 firmware install, the battery report says I had an effective 7 hr, 24 min of usage on a full battery.
    As to the person who says that they have a problem with IE links on an SP2, I have no problem whatsoever..
