2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-22T15:06:34+00:00
    UK, 256GB 4200u.
    I just had the 18/1 update again. Or at least it lists as if it was the same in my update history, but when it offered it to me it said Hardware Update and not Firmware Update. IIRC that's different this time. And it didn't do all that flashing-the-bios weird restarting stuff this time.
    Not sure what's changed. Hardware drivers it says, but I don't know which ones. Still have the Surface Cover Telemetry driver showing as missing.
    I've got two niggly problems that I'm aware of still:
    1. Battery remaining indicator can be all over the place. Sometimes seems fine, sometimes absurdly wrong
    2. WiFi adapter seems to hang when switching networks. Needs to be restarted to connect properly to a different network.
    Sleep does seem to be OK now though, and don't seem to have the 'black screen wake from sleep' crash any more.
    2014-01-22T15:32:48+00:00
    Well, then you have an exceptional copy of SP2. It makes you wonder if its worth to keep it or return it back for exchange. I have no other issue with the unit as everybody else describes here, except for a (compared to yours) very low battery life. 9 hours seems to be a bit exaggerated. How do you measure. I measure with an actual run of 5,5 h with office softwares before it shuts down, while you are maybe switching it on and off during the 9 hours period.
