2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-22T09:47:14+00:00
    Darwin Australia 4200u 256gb
    18th Jan update visible but fails to install, appears to install properly but doesn't show up in the update history.  When you do a clean up disk with system files, the update appears again. I've tried it several times now. Any ideas?
    2014-01-22T10:06:49+00:00
    I've noticed the same, powercfg says battery life is 4.5h now, was closer to 9h before this whole update mess.
    I still have sleep issues, while lying unused with screen off and the type cover attached covering the screen over night the battery level went from 50% to 6%.
    powercfg /energy says that USB Composite Device might keep energy saving features from working and that cpu usage is high. The cpu usage seems to come from two processes, audiodg.exe (30.9%) and svchost.exe (10.82%). Restarting the device does not affect the cpu usage of those processes unfortunately. There's also the device with driver failure that shows up as a potential issue.
