2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T22:18:31+00:00
    Well, I've got the January firmware installed, been operating on battery for two hours, watched Breaking Bad on Netflix, and my indicator is telling me 100%. So I'm guessing that isn't completely accurate.
    I have January update and all available updates also.
    This is unbelievable.
    1. Now it wont turn the display off on it's own.
    2. wont sleep on its own.
    3. When it wakes up from hibernate it re-sets up my SD card like it is the 1st time I inserted it.
    4. Battery meter is all over the board. now says 1hr 26 min with 69% charge.
    5. This is the worst PC I have ever owned in 30 years.
    6. I wish MSFT would just sell the design to someone who knows how to build a machine and a bios.
    eBay or craigslist bound if it ever gets usable.
    2014-01-21T22:32:28+00:00
    I installed the January patch, and battery is looking good, but the network adapter is no more recognized...! Also some Surface cover Telemetry drivers
    anyone else having network adapter issue??
