2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T22:06:21+00:00
    Another interesting thing I learned from this thread is about the powercfg utility.  If there is some list of other useful utilities it would be good to know about it.  You never know when you need more information.
    LifeHacker recommends Tim Fisher's About.Com guide to Windows 8 Command Prompt tools:
    http://lifehacker.com/learn-all-the-new-and-removed-windows-8-command-promp-508219884
    I've looked at the Fisher guide and it's pretty good.  In one section, he has an extensive table of commands added and removed over the history of WIndows.
    Best MS link I've found so far for the Command Prompt in Windows 8:
    http://windows.microsoft.com/en-us/windows/command-prompt-faq#1TC=windows-8
    At the Command Prompt itself (Windows key + X, then C or A for regular vs. Admin Command Prompt), if you type HELP at the Command Prompt, you'll get a list of commands that you can scroll through.  If you type <command> /? at the command prompt, you'll get HELP for a specific command.  If you type:
    <command> /<option> /?
    You'll get HELP for a specific option and so.
    Using an Admin Command Prompt is like editing your registry.  You'd better know what's safe to do and/or exactly what you're doing.  Otherwise you can mess up your computer Big Time.
    2014-01-21T22:13:38+00:00
    Be interesting to know what other people are seeing for working battery capacity after firmware update, particularly folks who had frequent battery drains, overheating, etc., and did not exchange their devices.  Also interesting to know what the average SP2 user is getting as estimated usage hours on a full charge.
    Many have said that you need to charge your battery to 100% and then discharge it below 10% before you start getting accurate reports of remaining charge.  However, I never quite understood how that translated into what you should do because the preparation protocol depends on the computer's display of remaining charge.  So I won't take seriously my remaining charge estimates until I've charged for a long time, used the battery long enough to get told to shut down or else, and then fully charged again.
    Others know much more about batteries than I do, but this is how I muddle through.
