2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T21:45:30+00:00
    Well, I've got the January firmware installed, been operating on battery for two hours, watched Breaking Bad on Netflix, and my indicator is telling me 100%. So I'm guessing that isn't completely accurate.
    2014-01-21T21:46:50+00:00
    Here's what the summary of Battery Life Estimate currently says for my SP2 after 16 full recharge-equivalents:
    Current estimate of battery life based on all observed drains since OS install
    Since OS install 8:10:24 - 8:10:50 -
    Before the firmware update, the Full Charge Capacity estimated usage hours-on left  (based on actual working capacity over time) was running 10 to 15 minutes lower than the Design Capacity estimated usage hours-on right for many weeks.  The 1/18/14 firmware update adjusted the full charge capacity estimates to put me back at ~zero wear level.
    Be interesting to know what other people are seeing for working battery capacity after firmware update, particularly folks who had frequent battery drains, overheating, etc., and did not exchange their devices.  Also interesting to know what the average SP2 user is getting as estimated usage hours on a full charge.
