2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T21:01:17+00:00
    So far, so good today after yesterday's firmware update:  Battery appears to be holding charge well and battery meter is accurate.  The screen dimming and brightening at random also appears to be fixed.  Fingers crossed that this will continue.  When this machine works correctly I love using it!
    2014-01-21T21:21:54+00:00
    The predicted battery usage left very much goes up and down with your recent immediate past usage.  Let the SP2 sit idle, the prediction may be > 10 hours on a full charge.  Do some processor-intensive tasks, the predicted usage may be 4 or 5 hours (or less).  Kinda like how battery life on laptops of old yo-yo'd according to how much you were making the hard disk spin .
    Also, if you look in the Battery Report generated by "powercfg /batteryreport" at the Admin Command Prompt, in the last section of the report for Battery Life Estimates, you will see an integrated summary of past battery life estimates for average usage over an entire week for several months back into the past and for the most recent week, for each day of the past week.  The left side of the report is estimated at Full Charge Capacity at the time (wear-level taken into account), the right side of the report at the ideal Desig Capacity of the Battery.  The final tabulation at the bottom of this section is the overall (average?) battery usage hours per charge you would be getting with actual capacity as you go on the left, design capacity on the right averaged over the lifetime to date of the device.
    The intent of this section is to give you an inkling of how your SP2 battery is holding up under the typical demands you place on it in a day, in a week, etc.  I guess it's basically designed to give you an idea of how many hours you can typically go before you need to look for an outlet and how fast the number of hours you can go is running down during the life of the SP2.  Perhaps MS thinks the final statistics more useful to customers than seeing their full battery capacity is at 37,000 mWh.
