2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T17:20:03+00:00
    The January firmware update has now appeared on the Surface Pro 2 update history page:  http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history
    A version number! Good improvement:
    "January 2014 update
    Updated UEFI firmware, version 2.04.0350, to resolve behavior where the Surface failed to enter sleep while idle, negatively impacting battery life."
    2014-01-21T20:58:32+00:00
    UK SP2 128. Firmware 18 Jan updated 12 hours ago.
    Well, I thought it was unlikely that MS had managed to get it right after all the preceding nonsense. At the moment after 4 hours very light use on a fully charged battery this lump tells me that with 54% battery left I have < 2hrs use available. 2 minutes later the same % tells me I have almost 5 hrs use left. Hmmm.
    Roy
