2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T17:30:23+00:00
    James, full agreement here. Surface Pro 2 implementation is crashing disaster.
    2013-12-12T18:37:44+00:00
    I just recently (3 days ago) received yet another warranty replacement Surface Pro 128. Second one in less than 10 months, but I still love the machine! It also has a Type cover attached as in always!
     After installing Office Pro 2007 I retrieved all of the currently available updates, installed 8.1, and then checked for updates again. There existed 49 updates with one being the hardware update of 118MB dated 12/10/2013. So I checked everything except Bing (pony pellets) and had it install.
      Keeping in mind that this is an exceptionally clean machine, but everything installed without error, and after a reboot I checked update history and it revealed that the hardware update installed successfully!
     A couple of observations here is that the greater amount of errors seem to be associated with Surface Pro 2 machines with the Type Cover 2? Also it seems that the cleaner (absent of add-on software) the machine the less likely for failure?
     Something for all to think about with further reporting to MS? I am not the worlds expert on these things, but have been doing techy type stuff since 1985. MCSE, MCSA, A+ Net+ Bachelor of Computer Sciences
