2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T12:30:53+00:00
    UK, SP2 128 user.
    Installed 18 Jan firmware release successfully - but slowly, needing a couple of cycles of the boot time installation. So far no problems although I'm using the device on mains power mostly.
    One question. I've been planning to buy a Bluetooth mouse to free up the USB port but I see many people stating that this cripples the wireless connection speed (2.4 router in my case).  Anyone running Bluetooth mouse or other devices know if this fault is resolved by the current firmware update?
    I wonder what else MS have got wrong with this product?
    Roy
    I've been using a Bluetooth mouse all along-have had no problems with it or my wifi connections.
    2014-01-21T12:50:23+00:00
    The January firmware update has now appeared on the Surface Pro 2 update history page:  http://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history
    There are a bunch of features listed for the December update.  I wonder how many of those one got if the update is listed as failed.
    For the last few days trying this URL from Internet Explorer 11 on Windows 7 has led to some endless loop of redirects, even though it was fine beforehand.  It is fine now in Chrome, however.  It makes you wonder what browser people use at Microsoft.
