2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T12:19:22+00:00
    Don't know about everybody else, but I found that:
    1. Cold Booting a SP2 factory firmware with an SD-Card inserted meant having "Client Runtime Server" csrss.exe hogging up CPU, lagging battery draining system, and a SP2 hot to touch. A sleep or restart fixes this temporarily :(
    2. On the other hand, cold booting an SP2 with Oct 24 Firmware installed (and with SD card inserted) would lead to "System + System Interrupts" running high but not as bad as csrss.exe in point 1. Again a sleep or restart fixes this temporarily :(
    Absolutely annoying.
    I have the same problem and perhaps this problem may affect adversely battery life and computer speed.
    For this reason I don't use the 2 MicroSD that I have bought for my surface pro 2. (64GB  54.41 Euro + 32GB  24.16 EURO = about 106 USD)
    I have installed the new firmware update 18/01/2014, but the problem of high CPU usage by System and System Interrupts, when I use a microSD card, is still an unsolved problem.
    Time for us all to tweet Panos at Microsoft about this silly ancient issue. I did.
    2014-01-21T12:22:37+00:00
    UK, SP2 128 user.
    Installed 18 Jan firmware release successfully - but slowly, needing a couple of cycles of the boot time installation. So far no problems although I'm using the device on mains power mostly.
    One question. I've been planning to buy a Bluetooth mouse to free up the USB port but I see many people stating that this cripples the wireless connection speed (2.4 router in my case).  Anyone running Bluetooth mouse or other devices know if this fault is resolved by the current firmware update?
    I wonder what else MS have got wrong with this product?
    Roy
    I use Razer Orichi Bluetooth 3.0, no lag with my 5Gz AC WiFi at all.
    Occasional drop out when you connect another Bluetooth device such as a Plantronics Backbeat Go 2 headset though, but I can live with that.
