2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T10:34:16+00:00
    Perhaps it was only a coincidence but I never received the rollback to the October update nor the January update until I did a reset of my Surface Pro 2. After I did the reset I first got the October update and after that had installed I got the January update.
    2014-01-21T10:59:12+00:00
    So far so good... got the update last night and tested with 'hibernate after' set to 1 minute, then reset power plan and left it sleeping for an hour, then left it sleeping overnight. Woke from hibernation each time. Also checked a few times putting it to sleep and waking shortly after as previous attempts to fix the issue led to it just hibernating immediately every time (NOT what it was set to do) and it is sleeping normally as well. So far looks like the problem is fixed. I had the erroneous battery meter twice shortly after the December update but managed to get rid of it somehow and it hasn't returned since so I can't report on whether that is affected by the patch.
