2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T06:55:11+00:00
    An interesting update... MS releasing the Jan18 Firmware Fix to ONLY affected Surface Pro 2 units. How does it do that unless it knows your mother's PIN number. A figure of speech, but seriously, unless they know specifically what they did wrong, there is no other way of tracing this! Or is there?
    http://www.pcauthority.com.au/News/370060,microsoft-patches-faulty-surface-pro-2.aspx
    And hence this silence is for the record:
    http://windowsitpro.com/microsoft-surface/surface-pro-2-removed-december-update-rolling-back-out
    Doesn't seem to be the case. The replacement unit I received yesterday is batch No. 1351, so produced after the Dec update was pulled. I was offered the Oct 24 Firmware on connecting to WU. Installed, all has been fine. Today I was offered the Jan 18 update, that also installed OK, and the unit hasn't thrown any tantrums Those two System firmware updates are the only ones listed in "Update History"
    2014-01-21T10:16:51+00:00
    I confirm.Just got my FW update on my SURFACE 2 Pro Device.
    18.01.2014 - installed 21.01.2014
    I'll give an update of the changes when I get back to my office
