2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T04:33:30+00:00
    Spending the day with a grandchild rather than a SP2, I could only read about all the updates coming through and wait to get home.  Sure enough at 10 pm, the 4.2 Mb 1/18/2014 firmware update was waiting and installed with no problem.
    Interestingly, some have reported the firmware update refuses to install unless the battery is fully charged.  I was running at 52% charge on just the battery and the firmware update installed no problem (although it seemed to reboot or the screen went blank 3 times showing the Surface logo and an announcement an installation was taking place.
    I had a failed 12/10/13 firmware update on that date back in December, ran Windows Update Troubleshooter, Disk Cleanup with System Files including Windows Update files included.  My installation history was wiped clean, began receiving Windows Updates again, never offered the 10/24/13 update  again (which succeed back in October, I think), and received a 12/10/13 hardware update on 12/11/13, and lots of updates after that including the 1/14/14 Patch Tuesday updates.
    Since December, I had no problems with charging or battery status indicator but did have my SP2 come on overnight while supposedly shutdown on at least 2 different occasions, the most bizarre being after the January 14th patch Tuesday updates.  My battery wear level is only about 2% after 16 full recharges but haven't fully recharged SP2 since 10/29/13 (lack of full recharge might affect accuracy of wear level estimate).
    Have just installed the firmware update and not checked everything out.  Have the curious problem right now that Windows key + X, then A does not generate an Admin Command prompt to run "powercfg /batteryreport". Will have to reboot and see....
    Texas in U.S. of A., 256 Gb, 4200U, lot 1341
    2014-01-21T04:56:38+00:00
    Hookah!  Not only could I not get an Admin Command prompt on two tries on first reboot after installing 1/18/14 firmware update but when I went to reboot, I waited for about 5 min with a RESTARTING message and the pinwheel stuff before getting the wonderful new pastel BSOD.  Something like DEVICE_POWER_STATE_FAILURE quickly flashed by.  However, next reboot went O.K and I could finally get an Admin Command prompt to run a battery report.  Instead of being at 41,437 or thereabouts, the Battery Report now tells me my capacity is 42,113 kWh (whereas design capacity is 42,002 kWh).
    Thanks to MS for the firmware update at last (and jazzing up our dull lives).
    EDIT: Another casualty of the firmware update is the Autocorrect setting on the Win8 Spell Checker.  When it turned "Hookay" (1st word in post) into "Hookah," I finally had enough and turned it off in Settings.  Kinda like firmware updates..... you never quite know how things are going to turn out with AutoCorrect at work.
