2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T04:13:11+00:00
    Long ago in a galaxy far far away, I used antistatic spray on the floor and my chair when a desktop computer wasn't turned on (and the room was very well-ventilated by forced air circulation).  Antistatic spray is probably not good for circuit boards, etc.  So if you can remove all your computers from the room until the air is cleared, a single spraying would probably last you the whole winter.  I would also touch the metallic case of the computer upon first sitting down, which was plugged in and grounded, but that probably doesn't do you much good for an isolated computer running on battery power.
    2014-01-21T04:30:09+00:00
    An interesting update... MS releasing the Jan18 Firmware Fix to ONLY affected Surface Pro 2 units. How does it do that unless it knows your mother's PIN number. A figure of speech, but seriously, unless they know specifically what they did wrong, there is no other way of tracing this! Or is there?
    http://www.pcauthority.com.au/News/370060,microsoft-patches-faulty-surface-pro-2.aspx
    And hence this silence is for the record:
    http://windowsitpro.com/microsoft-surface/surface-pro-2-removed-december-update-rolling-back-out
