2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T02:41:02+00:00
    The main things I did differently as a result of this thread were:
    • Knew what to avoid because of the power management issues (Type Cover left attached, use of Sleep).
    • Knew to avoid re-installing the 24 October firmware update that was offered a week or so ago.
    Another interesting thing I learned from this thread is about the powercfg utility.  If there is some list of other useful utilities it would be good to know about it.  You never know when you need more information.
    2014-01-21T02:45:19+00:00
    It could be the way my body builds up electricity more than others (I get discharged zaps a lot)
    People have different degrees of skin moisture, some to the extent that they have difficulty using capacitive touch screens.  That together with clothing and carpet fabrics can affect static electricity sparks.
    I grew up in a cold climate, and as kids we used to go around touching each other with a penny in the winter.
