2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-21T00:52:36+00:00
    UK SP2 / 128
    I am still being offered the October update but nothing for this month. Is the latter dependent on the former as I'm reluctant to install it?
    Boy, am I getting tired of this b*ll5h*t
    Roy
    EDITED
    Checking for updates via the desktop control panel shows the new update  but not the October version; checking via the sidebar PC settings menu shows the October update but not the new one. Yet more spectacular incompetence from Microsoft.
    I'll wait a while before installing the latest version. Now why would that be?
    I checked only the Desktop readouts, and also had the 24 October update disappear in favor of the 18 January update.  After charging the SP2 (and doing a disk image while that was happening, just in case) I installed the firmware update and nothing catastrophic happened.  I haven't tested what happens after hours in sleep with the Type Cover attached, or what happens at low charge, but I imagine that many of us will get the opportunity to test such things in coming days.
    The main things I did differently as a result of this thread were:
    • Knew what to avoid because of the power management issues (Type Cover left attached, use of Sleep).
    • Knew to avoid re-installing the 24 October firmware update that was offered a week or so ago.
    Ideally I should have known both of these things promptly by being so informed by an apologetic and  well-informed Microsoft representative helping out in this group and making public statements to reach a wider audience as well, but alas we don't live in such a world.  But I continue to think the Surface is a very important step in the right direction, and thank the community for making things work well anyway despite the unimpressive performance by Microsoft on customer service.
    2014-01-21T01:38:00+00:00
    Received the firmware update.
    Las Vegas, NV, USA/SP2/128/4200/Lot1341.
    Wonderful sailing!  Also MS did survey me when I stated I was searching for the firmware update..I requested that MS treat us as intelligent adults as we had all purchased premium devices and that we wanted them to function as advertised.  Right after received the update, perhaps a coincidence.  As an aside , this is the third or fourth time I was surveyed after searching at the MS Support site
