2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T14:08:55+00:00
    I haven't wiped the SP2 since i purchased it, so... my answer is 'no' you don't have to go through this every time Mr. Hanky splashes spinning fan blades. But being me is tiring 'cos I'm a perfectionist. This one's engraved on Microsoft's gravestone as one of the best royal screw ups yet. I mean who knows how many SP2 are cooking in their mums & dads' protective sleeves right now. But if your question is to wipe or not to wipe, eventually though like all things, they become overly concocted and corrupted and need to blow up to restore order.
    2013-12-12T17:14:17+00:00
    PLAGUED with issues and little or no response from Microsoft. Profoundly disappointing.
