2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T23:40:36+00:00
    Germany, SP2 Pro, 256GB:
    I got the update today, but nothing is changed. Unknown Device is still there, stand by isnt working and battery drain is still there. Now i contact the support for exchange the device.
    2014-01-21T00:19:01+00:00
    One of the issues this update is supposed to fix is wrong battery indicator. Every once in a while my Surface Pro 2 reports it has 5% battery left and refuses to recognize it is connected to the charger. Reboot or power off does not help in this situation
    • after a day or two Surface just crashes, reboots in Automatic resolution mode, then boots correctly and works for another week without issues.
    I was hit but this problem today, and here we go - can't install even firmware fix - it (understandably) requires a minimum level of charge for the battery or power supply connection, which my Surface won't report until the next crash. What a frustration...
    P.S. I'm on East Coast (Connecticut), didn't get firmware update available till this afternoon (and I was checking a few times a day since last Tuesday). I get it that Microsoft wants to take time and test the fix and so on, but I agree with everybody above who said there should be more communication. And a bit less of denial too - I remember it took them almost two weeks to admit there is a problem related to firmware. Had they accepted it sooner, who knows, we could have gotten a fix before holidays.
