2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T23:28:44+00:00
    Pennsylvania, USA SP2/512/4200U/Lot 4813
    Got the update and it's been smooth sailing so far.
    2014-01-20T23:36:59+00:00
    Roy, please wipe in from the right edge of the screen and then tap Settings, tap  Change PC settings, and then tap Update and recovery, tap Check now :)  I've installed it on my SP2/128 (with October firmware) couple hours ago.
    Alex.
    (C) Microsofthttp://www.microsoft.com/surface/en-us/support/install-update-activate/pro-2-update-history?lc=1033
    January 2014 update
    Updated UEFI firmware, version 2.04.0350, to resolve behavior where the Surface failed to enter sleep while idle, negatively impacting battery life.
