2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T23:17:21+00:00
    UK SP2 / 128
    I am still being offered the October update but nothing for this month. Is the latter dependent on the former as I'm reluctant to install it?
    Boy, am I getting tired of this *Moderator Edit*
    Roy
    EDITED
    Checking for updates via the desktop control panel shows the new update  but not the October version; checking via the sidebar PC settings menu shows the October update but not the new one. Yet more spectacular incompetence from Microsoft.
    I'll wait a while before installing the latest version. Now why would that be?
    2014-01-20T23:24:18+00:00
    Just received the update, hopefully it will solve the sleep and battery issues.
    I got it today as well. I hope it fixes the standby/hypernate issue...
