2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T22:36:38+00:00
    got the update;
    Germany, SP2 128 GB 4200U
    Systemfirmwareupdate - 18.01.2014 (installed 20.01.2014)
    4.2 MB
    Just booted after sucessful install (~3min updatescreen, then login screen)
    2014-01-20T23:04:02+00:00
    Got the update and everything is OK so far.
    UK, SP2 256GB 4200U
