2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T22:16:17+00:00
    Everything OK with todays firmware upgrade for SP2 U4200. Plugged-in, charging. Go ahead!
    2014-01-20T22:20:18+00:00
    Just received the Jan 18 update. Installed OK. This is on the third Surface Pro 2. First one was hosed by the Dec update, second performed OK till last Saturday when it refused to boot  - hardware failure apparently. That on was replaced yesterday, and when I fired up WU I was offered the Oct 24 firmware/hardware update. Installed that without drama. I was impressed with the Surface Support technician, he offered to arrange a replacement, but I decided I would see if the retailer would do it. They did so, without any waves. So while I'm not happy about the reliability of the Surface (yet) I give credit to both Surface Support and  Harvey Norman, Adelaide, Australia for the way I have been treated. The support tech plans to phone me today to see if I have received my replacement.
