2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T13:33:30+00:00
    It isn't much of a choice matey, as far as my short experiences in IT goes, Unix, Linux and Windows 7 (unupdated) proved to be the most stable. My Win7 PCs are always backed up using Linux Drive-Imager of sorts which means I can flash them good as new in minutes after serious crashes or attacks. Hence my machines like really kick ****. People say Mac OS' are stable because they run in house and certified apps, but I can crash them like demolition derbies. When you got systems running Frankenstein sourced applications like Windows with mixed hardware, your system is a fruit basket. The fact that Windows run as good as it is is a miracle. Unfortunately I can't seem to be able to successfully backup the Surface Pro 1 2 using similar flash methods due to its UEFI.
    2013-12-12T13:50:46+00:00
    So since you can use the back-up method you mentioned on the Surface Pro 2... you are saying the only choice is to wipe it all out and start over again?  Thank you for the input, but this is not acceptable to me.  What's to say I do this and it happens all over again???  MS just sits back and enjoys my hard earned money while I struggle getting their lame product to work?  No thanks.  I will be better off warning everyone through social media, etc. to avoid this product like the plague, and get a different machine that actually works.  I have had several windows based machines that can actually wake-up from sleep mode.  Why can't the hardware produced by those that made windows do the same thing???  Why does Microsoft have to suck so bad???  Very very frustrating.
