2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T20:03:57+00:00
    Has anyone who did not get the 18 January firmware update by 18 January have it show up later?  In other words, is there some continuous roll-out underway, or was there just a release to some by 18 January and no further release since then?
    It is looking like access to 1/18 firmware is dependent on your Update History.  If you show a System Firmware Update - 12/10/13 as Failed and a later System Firmware Update - 10/24/13 as Successful even though your firmware drivers are dated November, then it looks like your SOL.  My predicament, am I left waiting for the 1/18 firmware driver package to be posted for manual install?
    I spoke with a tech support person this morning who told me everyone
    would be getting an update within 10 days whether or not you installed the December firmware update. This article says the end of next week.
    http://m.digitalspy.com/tech/news/a545117/surface-pro-2-firmware-update-resumes-roll-out.html
    Just received the 1/18/14 System Firmware Update, in California Bay Area.  Now to test if it fixes my broken Sleep.
    2014-01-20T20:04:12+00:00
    Update from me: I just got the update :-)
    It looks like there is a continuous push of this firmware update. I really hope it works...
