2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T17:13:18+00:00
    I'm in the merry company of those who have received the December firmware update, which failed, have received the re-release of the October hardware update, which succeeded, but did not have any effect on the sleep and battery issues, and so far have not received any January firmware update.
    This is what I have in the update history concerning firmware/hardware updates (European date format):
    Name - Result - Installation date
    "System Firmware Update - 22/10/2013" - Succeeded - 22/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 25/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 10/12/2013
    "System Firmware Update - 10/12/2013 "- Failed - 15/12/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 04/01/2014
    So, the "System Hardware Update - 24/10/2013" in my case was actually installed three times, one before and one after the December Firmware Update. Is this comparable to what other people have received?
    Thanks!
    2014-01-20T17:20:11+00:00
    Thanks!
    I saw the 10/24 HW update once, then the FW update -- which succeeded, then the HW update (succeeded) and AGAIN the HW update (which I hid since everytime I have a WU I lose BT and wifi until i disable, and re-enable Marvell).,
