2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T17:05:49+00:00
    its a windows update. it'll be there until it gets superseded by another update. what would be the point of updates that are only there for one day? forcing people to be online every patch Tuesday? ;)
    I believe they are not releasing it to everyone at the same time, considering how bad it went last time. so they're getting feedback and can stop the rollout if there are more issues without affecting everyone.
    2014-01-20T17:06:20+00:00
    According to ZDNET, the company is sending out the updates in waves, rather than all at once, and more updates may follow."
    Public releases in waves are frustrating for end users.  It's the evening of 20 Jan here - and still nothing new in Windows update.
    Microsoft need to act more like Apple.  i.e. Release pre-release quietly to their MSDN/TechNet users game enough to try it,, and then release to the public when they make the public announcement.
    There are a number of reasons for this sort of thing, including concern over server overload, BUT frequently this is  done JUST IN CASE there is a FUBAR.  That way not everyone is affected.
    In other words, a lame attempt at covering their you know what's.
    Meanwhile, no update here.  In addition I could swear i hibernated last night but woke to it being very hot and on.
