2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T16:45:07+00:00
    I can also confirm that the 1/18/14 update fixed most of the issues.  my 128gb pro2 no longer turns itself on,  I had it in sleep mode starting at 100% battery and it lasted almost 2 days, with some minor usage.
    2014-01-20T16:49:55+00:00
    Has anyone who did not get the 18 January firmware update by 18 January have it show up later?  In other words, is there some continuous roll-out underway, or was there just a release to some by 18 January and no further release since then?
