2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T16:25:11+00:00
    For those who were fortunate enough to have access to the 1/18 firmware update, did it fix Sleep?
    It did fix the sleep issues with my 128gb surface.
    2014-01-20T16:39:28+00:00
    Thanks, good to hear but now I'm really bothered that I don't have access to the 1/18 firmware.
