2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T13:50:19+00:00
    There is some discussion on the thread http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfhardware/surface-pro-2-crashes-when-waking-from-sleep/17576a4e-2d85-465a-95aa-029e7b7f29b3 as to whether the hardware lot number makes a difference in the problems experienced.
    The lot number is on the label on the box in which the SP2 came.  My lot number is 1342, indicating 2013 week 42.  This information is not in the serial number, though I'm sure Microsoft has that mapping.
    This provides another factor that Microsoft could be using in rolling out firmware updates selectively.
    2014-01-20T15:32:19+00:00
    For those who were fortunate enough to have access to the 1/18 firmware update, did it fix Sleep?
